- My model of MX-5 is: Mark ii
- I’m based near: Cambridge
- I’m looking for technical help or recommendations on: ABS management lights
Hello all, This is my first post. Thank you for any help you can provide!
I have purchased a Japanese import mark ii manufactured in year 2000. It’s failed its MOT on ABS. The light on the dashboard is on permanently. I have given the car to a couple of garages who cannot fix the ABS issue. This is partly because they cannot find any connection for an ODB reader which they believe is unusual, stating that typically all cars post 1996 should have one?
I believe that I have established the actual problem with the ABS. I have followed the below helpful youtube link which showed me how to find the fault codes by placing a wire into two connection points in the ‘diagnostic socket’ which is located in the bonnet area (passenger side). This did provide a couple of codes and I have now replaced a sensor. The problem is that without an ODB reader I cannot attempt a computer reset that can hopefully remove the permanent ABS light. This is quite critical to do as I currently have the car on the road with a failed MOT!
I have heard that you can complete some emergency braking and this might remove the ABS light. Pretty difficult to do while the car is without MOT.
Being non technical, I don’t know if there is some kind of plug in reader between (I think) the diagnostic socket and (I think) and ODB reader that will allow for 1) reading the problem 2) successfully resetting the fault codes once the correct part has been fitted? Or if there are any suggestions please on what I can do?
Also, for the Cambridgeshire/Hertfordshire/Bedfordshire/north west Essex, would you know anyone I could take the car to to resolve the problem? I live near to Royston, Herts.
Again, thanks so much if anyone can help. I’ve only driven the car for a couple of days!
