I have had the engine management light appear on the dashboard of my 2006 NC, so phoned the RAC who plugged in their diagnostics and have said there is a fault with the Lower Oxygen Sensor on the exhaust. Has anyone had any experience with this, and if so is it easy enough to do at home, and will the light turn off once replaced or will it need a diagnostics machine to turn it off/clear the fault?
Mine failed a couple of months ago, but that was the one before the cat, I believe it’s fairly unusual for the lower sensor to go. I think access for the lower one is OK if you have ramps etc and I think you need a special spanner to make it easier. They are fairly expensive as well. I had mine done by the garage as it was in for other work at the same time. I think the fault will clear once replaced however you can by code readers from eBay for around a fiver and download an app such as torque lite that allows you to read the code and reset, One of the best buys I have made recently as helped me confirm that my thermostat valve was dodgy by showing the water temp.
Eddie, I was only trying to help and the op was looking for advice. Smarmy comments help no one. Companies sell a lot of things that don’t need replacing very often.
