Oil filter MK3/mk4
  1. My model of MX-5 is: __nd
  2. I’m based near: __
  3. I’m looking for technical help or recommendations on: is the oil filter for the MK3 the same as the mk 4 only I’m struggling to find a OEM filter for my nd. even went to my local Mazda dealer they said they were out of stock which seems incredible how are they managing to do a service
Mx5parts show Mk3 and MK4 filters as fit only that generation so I’d go with that they are not interchangeable.
I’ve used K&N filers in the past on my Mk3, they have those for the Mk4 at Mx5parts👍
Anyone know the difference between these oils,looking to do oil change on my NC3.5
I can tell you the FE is the recommended one as I use and many others.
As recommended in the “Everyday Protection” Tab.
You can use both, but the XE seems more for the Exhaust Car Reduction systems. :man_shrugging:
Check out the Mobil Lube finder with your car details.
Both seem to make the same claims other than the X1 Fe carrying various Ford & Mercedes approvals
The FE is the one I’ve always used, probably for 7 years over a 2 NC ownership.:+1:
Just to add, the blurb reads, recommendations for Ford engines, the Duretec engine.
