I need to replace one of the rear shock absorbers due to a knocking sound on one side when turning, going over bumps, etc. (just had new springs and antiroll bar done, but seems that the shock was damaged when the springs were fitted). Doing both rear shocks but no money for fronts as well.
The genuine Mazda shocks are not gas - so what are they? and what difference does it make?
If I get an OEM replacement that is gas, will that be compatible with the existing originals on the front?
I can get Monroe or KYB ones from MX5parts or Autolink. Any comments on these?
BTW I am not interested in lowering suspension - I’m happy to stay with factory settings.
To make things worse, I have a flat tyre and would be grateful if anyone can recommend a good online supplier for Yokohamas as Kwikfit do not stock them. I have a cheap replacement on one back tyre and really notice the difference stopping in the wet or on gravelly roads, so want to get a Yokohama like the others.
