Hi there,
My car overheated today and im trying to figure out the cause
I was out for a drive earlier today and after about 30 minutes of normal driving i noticed the temp gauge was reading a slight hotter than normal and then it took about a minute to shoot all the way to high, so i turned the engine off and pulled over right away, opened the bonnet to see steam/vapour coming from behind the power steering pump, the undertray was wet with a mixture of old oil and water. And there was no water at all in the radiator when i checked after letting it cool down. Also i turned the engine in again to check if heat was coming into cabin and it wasnt, but then the gauge was reading normal.
I filled the radiator with water and as i was filling it there was steam coming back up so the radiator was hot through and i think ran dry.
The expansion tank is halfway full however the water in there almost seems stagnant, if there is anybidy that has had a similar issue point me in the right direction that would be greatly appreciated
Chris
- My model of MX-5 is: __2.5 nb 1.6l
- I’m based near: __ Norwich
