- My model of MX-5 is: NB (Mk 2.5)
- I’m based near: Guildford
- I’m looking for technical help or recommendations on:
I have just bought a 2003 NB. I got it for a good deal as it has a P0303 engine code error. I did a bit of research before buying it to check it wasn’t too serious and gathered it should be a relatively easy fix. It had new spark plugs and coils before I bought it so I assumed it was the injectors.
A friend and I recently swapped the injectors between cylinders and it was still throwing up the same code for the 3rd cylinder (aka what we thought was the faulty injector works fine in another cylinder). We checked and there’s good spark and the coil is working fine.
Any ideas as to what it might be???
We’re currently thinking it the injector harness/loom?
It runs very smoothly for only 3/4 cylinders but definitely still has the misfire (backed by the code).
Any help would be greatly appreciated.
