on my 2005 MX5 mk3 NC 2.0, the EML came on Yesterday
I plugged a scanner in which threw up this code P0421 . Anyone else seen similar?
I kmow it’s related to the senors before and after the cat . Is it likely to be the cat or sensors? if a sensor, which one is likely? or is there anything else I need to check?
Can I add the car is not modified in any way, but I do use option for local 4-5 runs with a motorway blast every week. I did a search on the forum and know it’s either one of 2 sensors, or the cat. Which would you change first?
am investigating in investing in anew foxwell scanner for my other car (to wind back the EPB for a pad change) so will check it can scan for the sensors too . BTW, I agree about the parts lottery, which is why I asked!
Thanks for the advice. The thermostat was changed in the autumn and the needle definitely moves further (and heater is warmer) so I think that’s ruled out.
really appreciate the offer of the CAT, good lad. But I will get the rest of the sensors scanned first to rule them out. BTW, my simple scanner knocked off the EML but I’ve not been out since so can’t tell yet when the fault returns. I will update when I use it tommorrow
Well, I did a 40 mile run today, no issues, EML still off. Thinking about it, I was over a bit of bumpy track when it started so maybe theres a loose connection as a further possibility, to add to the sensors, and cat. I’ve ordered my new scanner today so,hopefully will be able to see exactly what’s caused it if it happens again.
I’ve had the car three years now, and given it was 12 years old with 98k then, it’s run perfectly with just basic maintenance .
