Pad and disc set
  1. My model of MX-5 is: NB
  2. I’m based near: Prestwick
  3. I’m looking for technical help or recommendations on: brakes__
Just wondered if these are any good?
The price is good but not sure which brand they are…
https://www.mx5city.com/brake-disc-and-pad-deal-mk1-18-mk225-1618/
These will be the usual never-heard of brand, which will be absolutely fine for the vast majority.
Cheaper here:
Thanks for that.
Would you recommend anything different?
Road use only…
For no other reason than never had an issue, EBC Ultimax pads plus AN Other Discs.
But I see Japanese Kashiyama pads and “Kavo” branded discs from Autolinkuk are £103 from Autolink lus, post, but before you take off the MX5OC discount. The code for this discount is listed here (Owners Club member only section):
https://forum.mx5oc.co.uk/t/parts-and-accessories/80993/2
If needing pads and discs right now, I’d have no hesitation.
Thanks for that.
I’ll take a look.
I used BluePrint items. Recognisable brand and part of Febi Bilstein. See links at:
