Keat63
29 January 2018 13:37
2
Is there an easy way to change the PAS fluid on a MK3 without removing any pipes.
I’ve considered removing the fluid from the tank with a syringe, refill, start and repeat a few times.
Doing a number of partial changes.
Whilst this won’t technically be a full fluid change, it’s probably the least messy way I could think of.
Keat63:
A turkey baster is very useful for jobs like this. I also use mine for removing old brake fluid before a flush/change.
The baster cost about £1 from Wilko. No, don’t use it for turkey juice before or afterwards…buy two!
ast
29 January 2018 17:45
4
Whats the purpose in changing the PAS oil. It doesn’t overheat, and become contaminated, unless at a herculean mileage. For every posting I see on PAS fluid change on a Miata having a great outcome, there is one where someone managed to get air in the system and screw up their previously perfectly good pump.
Keat63
29 January 2018 17:55
5
No particular reason other than replacing all fluids over a period of time.
If I change it now, I’ll never need to do it again for another 10 years.
