- My model of MX-5 is: __ 2018 MX-5 Rf
- I’m based near: __chichester
- I’m looking for technical help or recommendations on: __ passenger window stuck open.
I had my windscreen replaced yesterday by auto glass and now my passenger window is stuck in open! Any ideas if this is linked?
Have you depressed the lockout button on the driver’s side window switch panel?
Yes, I’ve tried the reset etc. Goes up about 3 cm and down and that’s it.
Seems a bit of a coincidence just after windscreen replacement. Worked fine before
Any metallic grinding noises? Likely to be a failed window regulator (very common).
There is a small Metallica grinding noise and then just nothing…. No noise just dead.
Window regulator has failed and will need to be replaced, its a VERY common issue unfortunately.
Do you think it’s just another coincidence then?
Yes, i can’t see how that would be linked to windscreen replacement.
Ok, many thanks for advise
. I have it booked in with Doctor MX on Sat… more monies
I had this issue - thread here - Window Regulator Ofiaich. Part cost me about £45 including vat and my mechanic fixed it and charged £40.00!
I remember cable on damaged regulator was rusted and frayed, hope you get sorted quickly,
Ofiaich
