Photograph of MX-5 RF Homura cocpit fusebox and earth point
Hi everyone,
Does anyone have nice photographs of the Homura cockpit fusebox and earthing point.
Ofiaich :grin:
Not at present, but I can take some for you over the weekend. From memory, is the fusebox in the passenger footwell?
Hi mxomatodis,
Yes! I’m not at home so can’t photograph mine! I think the cover pulls off easily but maybe the earth point is under the ‘ main plastic trim’.
I tried a Google search but didn’t find anything good, I’m working now but will try a a You-Tube search later!
Thanks,
Ofiaich :grin:
Here you are. Looks like the earth is on the right (engine bay end) below the red wires.
Thanks mxomatosis! ( correct spelling :grinning_face: )
Seems fiddly to connect an earth wire!
Hope your ‘treasure’ is out on the road!
Still working, Japan zoom meetings…
Ofiaich :grin:
Yes, I think the white plastic cable cradle would need to be moved out of the way to access the earth point.
Thanks mxomatosis,
Were you going to hot wire your phone? I seem to recall?
Ofiaich
Not sure what that means! Just going to use a USB C to C cable! No charging pad like the one in our Toyota.
OK…. I want to have the same setup as in my 2017 RF, I’ll do it when I go back home!
Hi mxomatosis,
Arrived home early evening and decided to take a look at the fusebox but couldn’t find the knack to remove the cover!
Is there a tab to push in to release it? I thought with a little effort it should pull off!
I’ll look again in daylight!
** cover came off with a little extra help…
mxomatosis! Your photo is much clearer than mine! Thanks again!
Ofiaich :grin:
