i managed (unfortunately) to spread some polish off the bonnet onto the plastic scuttled trim at the base of the windscreen. This has left an unsightly grey line around some of this trim. Looks awful, I’ve tried my best to clean it off but no luck. Any suggestions? Some of the interior plastics also look a bit “lifeless” so maybe whatever gets suggested will work there as well?
Thanks guys! All your responses are what I wanted. Inexpensive, easily obtainable products. The simoniz seller on eBay is a couple of miles from me, Motosave has the back to black, they are a 5 minute walk from my home. Asda has the peanut butter, 5 minutes drive away and the baby oil is in the bedside cabinet I’ll get cracking and thanks again!
If you don’t like the taste of peanut butter, use your wife’s toothbrush.
I’ve also used the “instant shine” type of black boot/shoe polish to good effect on black trim (the sort in a bottle with a foam applicator).
That stuff works on tyres, too.
Thanks guys for the continued advice and recommended products I tried a few of the suggestions ( not spending any money ) and in this instance, so far, the boot polish suggested by Paul W has sorted the issue out! I had some under the sink and its coloured the trim really well? Obviously not sure of durability but looks good so far. I need to be more careful when polishing in that area in future!
I’ve also used the stuff to dye a replacement support “string” for the rear parcel shelf of my old Suzuki Swift. I couldn’t find any black cord at the time, so I used white curtain cord and dyed it black. Next time I’d wear rubber gloves though… it took some getting off my fingers.
