Powder Coating
Thinking of having the Cam Cover done found
http://www.ctc-powder-coating.co.uk/
In Maldon … Below are the car prices from them … seems reasonable
Option 3 "Chrome Silver add 30% to cost
  Option two. Shot blast zinc coat, polyester finish coat. (any stock colour)
  Option one shot blast & zinc coat     Shotblast Shotblast Shotblast
        Zinc Coat Zinc Coat Zinc Coat
        TOP COAT
  CAR / VAN PARTS       ANY
          STOCK candy/lacquer
          COLOUR
  Alternator body.   any stock colour £7.00 £10.00 £12.00
  Alternator brackets.   any stock colour £3.00 £4.00 £4.50
  Air filter inc. cover.   any stock colour £10.00 £15.00 £18.00
  Auto G/Box casing.   any stock colour £38.00 £54.00 £60.00
  Axle casing - small.   any stock colour £23.00 £32.00 £38.00
  Axle casing - large.   any stock colour £43.00 £61.00 £69.00
  Anti roll bar.   any stock colour £12.00 £16.80 £19.20
  Battery mount.   any stock colour £5.00 £7.00 £8.00
  Battery clamp.   any stock colour £2.00 £2.80 £3.20
  Bonnet, boot, door, catches.   any stock colour £3.50 £4.50 £6.50
  Brake plates - ea   any stock colour £6.00 £8.00 £28.00
  Brake drums - ea   any stock colour £6.00 £8.00 £28.00
  Brake callipers - ea small   any stock colour £6.00 £9.00 £18.00
  Brake callipers - ea med   any stock colour £7.00 £10.00 £20.00
  Brake callipers - ea large   any stock colour £8.00 £12.00 £24.00
  Brake / clutch pedals - ea   any stock colour £5.00 £8.00 £9.00
  Brake discs - ea   any stock colour £17.00 £24.00 £26.00
  Bumper. (subject to size & prep work)   any stock colour £25.00 £35.00 £40.00
  Bumper irons - pair.   any stock colour £8.00 £11.20 £12.80
  Cam / rocker box  Small   any stock colour £8.00 £15.00 £20.00
  Cam / rocker box med/large   any stock colour £10.00 £20.00 £30.00
  Cam / rocker box.   any stock colour £12.00 £16.80 £19.60
  Coil (ignition) mount.   any stock colour £1.00 £1.40 £1.60
  Coil spring - pair.   any stock colour £20.00 £28.00 £32.00
  Coil spring cups.   any stock colour £3.00 £4.20 £4.80
  Carburettor body.   any stock colour £18.00 £25.00 £35.00
  Coolant pipe - metal.   any stock colour £4.00 £5.60 £6.40
  Crank case vent pipe.   any stock colour £2.00 £5.60 £3.20
  Cylinder block.   any stock colour please call
  Cylinder head.   any stock colour please call
  Distributor body.   any stock colour £7.00 £9.60 £11.20
  Dipstick tube.   any stock colour £3.00 £4.20 £4.80
  Dipstick.   any stock colour £3.00 £4.20 £4.80
  Drive shafts.   any stock colour £14.00 £19.60 £22.40
  Drag link.   any stock colour £10.00 £14.00 £16.00
  Engine cross member.   any stock colour £28.00 £39.20 £44.80
  Engine mounts - pair.   any stock colour £7.00 £9.80 £11.20
  Fan blade.   any stock colour £3.00 £4.20 £4.80
  Fuel tank.   any stock colour £30.00 £42.00 £48.00
  Gearbox bell housing.   any stock colour £20.00 £28.00 £32.00
  Gearbox cross member.   any stock colour £8.00 £11.20 £12.80
  Hand brake lever.   any stock colour £5.00 £7.00 £8.00
  Header Tank small   any stock colour £12.50 £20.00 £30.00
  Headlamp bowl.   any stock colour £7.00 £9.80 £11.20
  Headlamp rim.   any stock colour £4.00 £5.60 £6.40
  Heater box covers.   any stock colour £6.00 £8.40 £9.60
  Horn rim.   any stock colour £1.00 £1.40 £1.60
  Inlet manifold.   any stock colour £15.00 £21.00 £24.00
  Master cylinder body.   any stock colour £13.00 £17.00 £20.00
  Pan hard rod.   any stock colour £8.00 £11.20 £12.80
  Plenum chamber.   any stock colour £14.00 £20.00 £22.00
  Plenum chamber cover.   any stock colour £6.00 £8.40 £9.60
  Pulleys.   any stock colour £3.00 £4.00 £4.50
  Radiator mounts.   any stock colour £3.00 £4.00 £4.50
  Rocker cover   any stock colour £8.00 £12.00 £20.00
  convertible roof assembly   any stock colour £40.00 £75.00 £100.00
  Rag top roof stays.   any stock colour £7.50 £10.00 £12.00
  Roof rack small any stock colour £25.00 £45.00 £60.00
  Roof rack medium any stock colour £35.00 £55.00 £70.00
  Roof rack large any stock colour £40.00 £65.00 £80.00
  Roof rack van any stock colour £65.00 £95.00 £140.00
  Steering column.   any stock colour £10.00 £14.00 £16.00
  Steering wheel.   any stock colour £10.00 £18.00 £22.00
  Sub frame. small   any stock colour £45.00 £55.00 £65.00
  Sub frame. med   any stock colour £50.00 £60.00 £70.00
  Sub frame. large   any stock colour £60.00 £70.00 £80.00
  Sump pan.   any stock colour £20.00 £28.00 £32.00
  Switch panels.   any stock colour £3.00 £4.20 £4.80
  Stub axle.   any stock colour £15.00 £21.00 £24.00
  Thermostat housing.   any stock colour £3.00 £4.20 £4.80
  Timing cover.   any stock colour £10.00 £14.00 £16.00
  Transmission filling tube (auto).   any stock colour £5.00 £7.00 £8.00
  Window frames.   any stock colour £15.00 £21.00 £24.00
  Wiper arms. small any stock colour £4.00 £5.60 £8.00
  Wiper arms. medium any stock colour £4.50 £6.60 £9.00
  Wiper arms. large any stock colour £5.00 £7.60 £10.00
  Wishbones (pressed steel).   any stock colour £15.00 £21.00 £24.00
  Wishbones (tubular).   any stock colour £10.00 £14.00 £16.00
  Wheels - alloy   any stock colour £30.00 £48.00 £56.00
  Wheels - steel.   any stock colour £28.00 £45.00 £56.00
  Wheels - alloy   any stock colour special fantasy   £85.00
  Wheels - steel.   any stock colour special fantasy   £85.00
  Trailer / caravan Wheels - steel.   any stock colour £22.00 £45.00
Sounds good price had mine done in Clacton they done good job ,got mk1 inlet manifold ready to coat if anyone intrested has been bead blasted .
Is it 1.6. or 1.8. and what year ???
Hi its a 1991 1.6 mk1
Les, NO!
No no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no !!!
Whats that all about ?Don't know
                          Is that a… NO… then…it was just a thought ???
 Yes Les I know your thoughts :slight_smile:
            NO No no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no on no no no no no no no no no no …YES… You do !!!
