All good questions and very happy to expand.
Why am I even trying this? I am looking for something different to do and a kitcar is for me a great idea. I don’t like either the Caterham 7 derivatives or some of the more extreme kits such as the Exocet, but I came across a couple of companies making kits based on much older cars. Some of these are rebodies of older chassis, others are full kits.
The D Type is a stunning looking thing and I have decided - I want one! However, all the examples I have found so far (that are affordable) are based on older donor cars such as Heralds or Spitfires. I’ve had an MX5 before and loved it, and moreover I want something modern and reliable underpinning the kit, and have no intention of rebuilding an ancient Triumph.
I’ve given myself three options:
- A full kit including body made by ANC Sportscars (http://ancsportscars.co.uk/). This is actually an Aston Martin DBR1 bodyshell (well, nearly) applied to an MX5 PPF and a bespoke spaceframe. Advantages - very easy to build and a great result, plus the shell comes with a polished gelcoat meaning I can hold off on a paint job for a while. Disadvantages - requires an IVA/SVA approval, and it’s not the D Type!
- A rebody of an MX5. Tribute Automotive make the body (http://www.tributeautomotive.co.uk/dtype.html) but I’d have to retain the donor bodyshell. Advantages - much less costly, no IVA/SVA required. Disadvantages - means relying on the tub being sound, it’s less neat than the spaceframe solution (which the D’s had), needs painting (not supplied with finished coloured gelcoat) and makes the vehicle heavier overall.
- A third way might be to merge the two - buy the spaceframe from ANC and the body from Tribute and combine. That’s the most expensive route to market - easily £4000 for the spaceframe plus the IVA, but it would be the most elegant and complete solution.
The scale measurements are taken from a particular series of drawings of the D Type; although there are plenty out there, having measured and scaled I’m happy that this particular image is as representative as I’m going to get. Matching that to an MX5 drawing was relatively easy, and the attached image (crafted in exquisite PowerPoint!) shows the differences in ride height and wheel diameter - however, overall body height is about the same. I hope the image link works… The body outlines are representative - I can cut a lot away from the rear especially although I plan on incorporating a useable boot space.
I have estimated the base MX5 ride height to be around 190mm (floorpan to ground on standard wheels), and the Jag sits at 140mm so that’s a 50mm drop. Any increase in overall wheel diameter will need futher lowering IF (and I say again, IF) it’s practical and necessary. I have no intention of compromising driveability - it’s meant to be a fun car as well as good looking.
In terms of containing the suspension within the bodyshell it’s not a problem; the ANC kit shows the fit nicely (see here: http://ancsportscars.co.uk/gallery_gen/656c85754b9f4c2db766a1b4dcd104c9.jpg), the Jag bodyshell has large bulges over the wheels anyway, and the suspension pillars will fit under the shell even when the body is fitted closely to the donor. The body will not really go much lower than the front scuttle as the engine gets in the way anyway - I’m not up for trying to fiddle the engine mounts as well.
Assuming I lower by 50-80mm, how severe is this likely to be - can I safely assume this will need adjustable coilovers, or is that the gold-plated route? If this becomes the limit, then it will drive the wheel size I end up with.
Hope that’s vaguely interesting!
