Looking at the photos, its fairly obvious both rear arches have blown; where the wheel arch lips have bent outwards is a sign that rusting has started. If the bubbled paint is rubbed down, I would expecting to see pinholes or larger. Its had at least one sill repair, so the other one won’t be far behind, but I would be expecting within the next couple of years paying to have both sills and arches cut out and replaced. 20017; advisory about “soft sills” (rot on nearside). 2011 and 2012, advisories about rusting around seatbelt anchorage (aka sills) on the offside.
Given the condition of the sills, I would be expecting that rusting will have started in the front chassis rails; it may not be visible yet, as the rusting is from the insider out.
If you need a NB-FL automatic, your choice is going to be extremely limited, as only a few hundred UK-spec cars were sold here.
I would be looking to get the price closer to £1500; worst case is the bodywork in 2 years or so will need £1000-2000 spending on it, likely not all at the same time. If you give yourself a cushion of £1000 plus normal servicing per year, you might sleep easier. I look at the MX5 body as a service item; it will rust, and it will need repair, and this is part of the cost of ownership. The rusting arises because it is not a tintop. Rusting is bound to happen on a car where the design allows water to drain through a unibody, where there is a complex of sill reinforcements, full of various moiture traps.
Likely, given the mileage, and the pretty clean MOT history (https://cazana.com/uk/car/Y84CER) I wouldn’t expect anything mechanical untoward. Only two owners, so no redflags in terms of being crash repaired auction fodder. I’ve not heard of any particular issues with the autobox, though its a little strange to see photos of the car with the engine turned off, but the shifter in drive, and not park.
What are your expections of a professional car inspector and what is now an 18 year old car? I expect any inspection report to be full of so many caveats as to diminish its worth. A sill has been “repaired”, but he/she can’t gauge how well that was done. If the other sill is looking “soft” (whatever that means. I am assuming it crunches a bit under pressure), they will give you the worst case (needs chopping out). If it were me, I wouldn’t bother with paying for an inspection (if you can get a local enthusiast to tag along to give you confidence, by all means). He’s not going to be able to check everything that you want him to check. You will be able to get a good feel about how well the car has been looked after.
When buying a Mk2, like the Mk1, if you embark on the buying process with eyes wide open, it’ll be a lot easier. Too many stories of people searching endlessly for that unicorn car. If you don’t like the idea of dealing with rust on what is now technically a classic car, you need to up your budget a bit and look at an NC. More autos, but don’t look at the very cheapest NCs.
