Proposed increased levels of Ethanol in petrol?
Any comments from forum members on press reports regarding the proposed Increase of Ethanol in petrol from circa 2020. Mazda MX5s listed as one model of car that will not be able to run on this new petrol?
Scaremongering by the press?
See https://www.mx5oc.co.uk/forum/yaf_postst38100_BIOFUEL-TIMEBOMB---Bad-news-for-pre-2002-MX-s.aspx
Already discussed.  Run a search on E10 for more info.
In short:
 - Mk3 are apparently fine
 - Mk2 and earlier may have issues due to supposed issues with E10 hardening fuel lines, injector seals and fuel pumps.  The US websites I looked at were suggesting that the damage can take 2-3 years before action is required
 - I approached my local Mazda dealer (Croydon) in Aug.  They themselves are waiting for communications from Mazda UK to clarify
 - E10 is already for sale in Germany and some other countries, so they probably have a better idea of risk than us
I’m not sure they would do this without offering some form of alternative… would they. ??
What about all the classics.
I remember going through this in 2000 when 4 star was banned, there were alternatives in the form of Lead Replacement Additives and cylinder head modifications.
I’d imagine something similar with E10
Mazda
E10 petrol is cleared for use in all models with petrol engines introduced in and from the
year 2002, Mazda6 (GG/GY) and models with petrol engines introduced thereafter.
That is potentially ambiguous.
It could be read as and of the following:
 - All Mazda cars built from 2002 onwards are compliant
 - All Mazda cars with newly introduced engines from 2002 onwards are compliant.  (in the case of the MX5, the VVT engine was brought in on that year IIRC)
 - All new Mazda models introduced from 2002 onwards are compliant, i.e. that the NB was introduced in 98’, and isn’t compliant, but the NC, brought in during 2005 is fine
I’m still waiting for a completely unambiguous statement.
Apparently (or so the Wiki suggests) at one time Tesco used 5% Ethanol as an octane booster in their 99RON fuel.  Do they still?  One of the problems with ethanol is that it corrodes aluminium.  However if there is some water in the ethanol, the water reacts first and protects the aluminium from further damage.  But if there is water in the petrol, does this rot the fuel tank?
There are a lot of E10 mandatory fuel mixes around the world, and I guess the car needs to have been designed with all this in mind.  I would be very surprised if Mazda were not compliant.
However, do you remember New Formula Shell in the 1980s?  Lead free…
I had just rebuilt the engine, everything except regrinding the crank on my old 1977 Mk1 Cavalier (a very cheap buy because the engine needed doing). So you can imagine my annoyance when ALL the valve seats and valves on both inlet and exhaust were pitting and losing compression etc after only eight thousand miles pottering around London.  The Shell garage was nearest and cheapest, and the girl behind the till very, very attractive and sunny, so it was an obvious place to buy petrol.
I needed to have steel valve seats put into the cast-iron head and lap in a new set of harder valves.  We then used that car for another twelve years or so.  I can see oddities like that cropping up with the E5 and E10 fuels on cars not designed for them.
Bit like Burr-exit then.
I’m struggling to see the ambiguity.
year 2002.
I guess you could have a 2001 car which had been sat in a field for 12 months.
Real World Experience
will 10% ethanol damage my '91 Miata? - MX-5 Miata Forum
OKOK I gotta ask , is 10% ethanol in my gas ...... - MX-5 Miata Forum
Is 10% Ethanol OK for the NA 1.8L??? - MX-5 Miata Forum
10% Ethanol in gas....? - MX-5 Miata Forum
E85 Long Term Use - MX-5 Miata Forum
All this talk of fuel reminds me its been a while since I’ve run a can of Proboost through a MX5.
Point well made By Saz methinks - no argument from me. Only point in above posts is that NBFL’s were available here from August 2001, so to say the model was first introduced in 2002 is not true. Mine was built later in October 2001, though available at the dealer one week before I bought it at the end of February 2002; - and I’m not losing any sleep over E10 after reading all those quotes.
Reviving this thread, as the topic is back in the news. Nothing new from stateside to suggest E10 is harmful to older cars. Gets a bit more uncertain with E15.
Nothing new with Ethanol as fuel, as Saz pointed out in the earlier post.
I think E100 fuel is the future, with hybrid regenerative braking using new technology super-capacitors to minimise use of Lithium.
See much more about how Brazil has produced and used it in various blends, and made suitable vehicles for many years in the long, long and detailed Wiki article.
The uncertainty, and it would be impossible for Mazda to really determine, is the compatability of pre-2002 rubber on MX5s with the ethanol content. I suspect that all VVTs should be treated as effectively the same.Its probably also correct to assume NB6-FLs also contain simlar rubber materials. Logically, you would think that NB8 and NB6s would have similar rubber, but there is a significant different in the engines used. And further difference with NA6 and NA8 (phase 1 and phase 2).
Anecdotal evidence is that E10 is backwards compatible with Mk1 and Mk2 models.
There are three issues arising to consider with increasing ethanol content:
  1. Compatability with fuel lines, tank lining etc.
  2. Octane rating
  3. Increasing ethanol content increases absorption of water into petrol, ie. ethanol-petrol goes off, and the more ethanol in it, the faster it goes bad. An extreme result is damage to a fuel pump.
Hard to find evidence of sustained running of older cars on E15 and above, except that occasional refills with lower ethanol content fuel is recommended. The issue with higher ethanol content fuels is that it not mixed by the oil companies, and so the Americans are seeing variations in quality and consistancy.
I suppose it might mean those who store their cars for extended periods haave to be more mindful of the fuel in the tank.
