Does anybody know how much my car weighs? I know the stock figures (although people seem to differ even on those) but I’m sure mine but be lighter due to the spec.
It’s a 1996 1.8 UK spec. but has no power steering, no airbags, no heated seats, no ABS, no electric windows, no nothing. Surely those things must all weigh something, but is the official weight just the car BEFORE those things are taken into account?
It must be on the lighter side as I have a similar aged MK1 with the detuned 88bhp 1.6 engine and there really isn’t that much performance difference when compared to Our Eunos with a good 115bhp engine.
As above, best bet is to find a local public weighbridge and just weigh the thing.
For vague comparison my mk1 clio which weighs about 1000kg stock I’ve completely gutted, right down to no dashboard or blowers etc but with a full cage adding weight back in and that’s 850kg on the bridge now
On paper, the detuned model was over a second down 0-60 on the earlier car, and that was after the various weight saving Mazda carried out on this model (and maybe timing tweaks to try and narrow the gap)
While there is debate about the savings removing chassis bracing, PAS pump, ABS (most MX5s never had this), to counter balance that, you also need to include consideration of the additional 21lbs from having the 14" steel wheels fitted (what most base models received), which is 21lbs (~10kg) increase in unsprung weight (arguably, a greater impact than 21lbs lost in the engine bay), and the impact having the slower (ratio) manual rack fitted (the manual rack is not the power rack depowered (2.8 turns lock to lock on PAS, 3.3 turns on manual racks).
The usual effect of aircon on performance, in older cars, is a drag on performance. I had a 1992 Honda CRX HF; billed as the lightweight special (no back seat, parcel shelf, single mirror, slim seats), in reality, it was the wheezy 70hp model designed to meet CAFE, and pull Honda’s average MPG up. The aircon in that car was dumb; switch it on, and it felt like suddenly a sack of spuds was thrown in the back. In the MX5, its a cleverer system; under wide open throttle, the aircon clutch will disengage. In otherwords, day to day driving, the only difference you will notice is slightly worse MPG. Traffic lights drag; no difference, and the Eunos wins out on the right hander, because of its vlsd.
The 1989 Eunos Roadster is close to the stripper poverty spec 1997 1.6.
On paper, the Roadster (no braces, with PAS, PW, alloy wheels): 940kg (115hp)
On paper, the UK 1997 1.6i was 922kg (88hp)
Still not enough to overcome the power-weight ratio deficit.
The 1.8i would be about 954kg, versus 980kg of the run out S-Package. But that run-out S-Package had a 4.3 Torsen not the 4.1 open diff, so quicker off the line, and through the corners.
So I assume that listed curb weight of 954kg is the base car without the extras. So since mine has only the 1.8’s extra bracing, I should be under that tonne mark. Happy days!
No, 954kg is a educated guess, based on how kerb weights are measured for the Japanese market, which is different from the European and US markets. And you are still left with a steering rack that is hated by the designers of the MX5, the heavy flywheel, and heavy steel wheels.
Bob Hall (Father of the Miata) hated the manual rack. And has ranted about it for the last 30 years, if anyone would care to ask him. Having had a M2-1002, with that infamous steering setup, I can agree with his sentiments. Some quotes from him:
Allegedly, the 96-97 PAS is close to what Mazda really wanted.
