Good evening
I’ve heard that the radio does not need a code entering after powering off at the battery… I need to disconnect my battery but I’m reluctant at the moment.
Can anyone confirm the above,ie no code needed.
Many thanks
-Steve
Good evening
Many thanks
-Steve
Radios in the NC are not coded from the factory but can be coded by the user. Best thing to do is try to input a code as per the Owners Manual, if it lets you you know the code.
Mine didn’t need a code when I reconnected the battery, same year 07 plate sport. Have read that they can be coded though, so it’s a case of
Ok, thank you for your replies, I will have a read of the manual
