well if you are going to do it,going to a paint factors and get them to mix the paint and make you large cans of it,key the paint back with 400 grade wet and dry,then go over it again with 800 then 1000,buy a tin of paint isolator and spray that on.if your doing your boot lid or bonnet,flat back the adjacent wings with 1000s,to get a good key so you can blend in to the wings.
primer the boot and bonnet but not the wings,when dry flat back with 800s and then 1000s,this will give the paint a good key.spray your top coat on lightly,its best to hand the panels up rather than have them on the car if your using cans,give it 5 mins to flash off,it will look powdery but dont worry,apply another coat and give another 5 mins,the trick is not to use the full can,as it starts spitting paintâŚso use about 3/4 of a can,and then get another.give a day to dry. you need to know whether its clear over base paint,or straight base coat.The way to find out,is go to a part of the car you cant see,get some fine wet and dry and rub it,if its show no colour its clear over base,which means it has a laquer on it,if it shows a colour its a straight base coat.
on the wings,after a light rub with 1000s,get some scotch bright and rub over where you have took back,and go a further inch with the scotch bright down the wings,mask off a further inch down the wing.
at ever stage make sure you wipe down with panel wipe,and buy some scat rags,these pick up any contaminates on the panels.
if its a straight base coat,ie no laquer,lightly flick the paint over the edges down the wings down to just over where you have rubbed with scotch brightâŚwhat you will find is where you have not scotch brighted,the paint wont stick and will blend in.
if the car has laquer,fit the bonnet and boot lid,wipe with panel wipe and scat rags,mask under the bonnet and boot,and then laquer the bonnet/boot lid first and flick over the edges of the wings.
allow a day to harden,then buy some fareglade rubbing compound,and apply lightly to wear the edges you have painted up too,use lots of water as you do it,so it does not cut to much.
if you get stuck come back to me on here!if any one needs any advice on anything car or insurance related drop me aline,iâm a motor insurance engineer and am glad to offer advice.
regards
TimÂ
Â
