Hi There, I have a 2002 mk2.5 Auto and I am looking for a pair of Rear Light Cluster Seals, can anyone point me in the right direction please. Graham…
Autolink or mx5 parts or I have simply used Screwfix Mastic in the past
Thanks for that…
Which seals? as the NB as a rubber grommet on the light cluster loom and just a couple of fiber washers .
M-m
I thought there was a foam/rubber seal that goes in-between the outside edge of the rear light cluster and the bodywork, Graham…
Might just do that, nobody will see it and probably be a better fix…
Why not just take a rear light off and check for yourself?
As Mazda Mender tells you, these do not have the full seal that the MK1 does, just small sealing washers. The body construction is different with a metal pouch that receives the light and allows water to flow in an around the light and off the car.
Compromised high level brake light seal might be the problem here if your issue is water in the boot?
Im going to once the weather warms up a bit, also going to check the high level brake light as well…
