Rear lights not operating
  1. My model of MX-5 is: mk3
  2. I’m based near: Chelmsford
  3. I’m looking for technical help or recommendations on: when i turn on my lights, the headlights work, but the dash doesnt, more importantly neither do the rear tailights. Sometimes light up after a minute or 2. Any ideas please?
Is the carpet in the psssenger footwell wet??,
Classic water leaking from the scuttle gromets and causing random electrical gremlins.
No the carpet is dry-dealt with that issue a while ago!
Do the front sidelights work? What sometimes lights up after a minute or 2, the dash lights or the tail lights or both?
The dash & tail lights come on (sometimes) after a few seconds, sometimes longer. Now you mention it, not sure about front sidelights, will check tomorrow.
Have you checked the fuse, maybe a dirty connection etc. looking on this diagram I found, this may all be related to the same fuse.
Thanks for the suggestion, ill take a look at the fuses.
So did you look at the fguses and have you sorted the problem please. I have a similar problem with rear lights and instrument panel OK - front sidelights not!
Hi, cleaned up the relevant fuse, seemed to cure the issue…
Certainly worth you trying too!
Hi. Thanks for the thought, cleaned fuse - no different. New fuse , no different. But all rear lights and instrument lights working perfectly! Auto electrician now booked (I had hoped top avoid the expense!)
