2003 mk 2.5 Nb
I have a rear suspension clunking noise from the near side only when going over rough ground, anybody point me as to where I should start looking. have checked for any loose objects in the boot and the exhaust seems ok
2003 mk 2.5 Nb
From your comments it appears you are not technically minded as you have not looked underneath the car or you do not have the kit to do that.
I would take it to the local garage and get them to check the antiroll bar droplinks and when it is in the air give it a general once over.
I would also check for a cracked rear spring; they tend to crack towards the top. Double check the battery and spare wheel are secure as well.
+1 for possible worn drop links.
I used to buy spares had about four or five kicking around!
