Hi all. I’m soon to invest in MeisterR crd coilovers, and would them fitted and aligned by someone who really knows what they’re doing! - preferably someone in the south of England e.g Hampshire, where I’m based.
Any recommendations for good suspension fitters etc?
My model of MX-5 is: 2006 NC
I’m based near: southampton
I’m looking for technical help or recommendations on: suspension fitters
Demec, https://www.demeccarservices.com/ (Basingstoke) is apparently where Skuzzle (Skuzzle Motorsport) is now located. I doubt MX5parts will do much beyond fitting.
But Nick (ex Skuzzle mx5 motorsport) works at Demec car services in Basingstoke, he was very helpful and he installs coilovers.
Alternatively there is a mobile mechanic in Suthampton that I use for both my cars who is excellent - Ryan of RW Automotive. I’ve also seen his rebuilt Honda Integra type R, he’s very good.
Just double checked… and looks like Nick has recently moved across to Bassett Down Balancing in Hungerford, and he offers Mx5 work as part of his job there.
I bought some Tein Flex Z coilovers about a month ago from Bofi Racing, had a phone call last week to say there’s a delay by Tein and they’ll be here at the end of October. So I don’t think the CRD are the only ones hard to get. Although I did look at getting those and couldn’t find anywhere that could get them, hence getting the Tein Flex Z instead.
coil overs means a shock and spring that is basically a 1 piece kit?
rather than a separate shock and spring that becomes 1 piece once fitted to the car?
Yeah basically, they tend to have adjusters on them so you can easily adjust the height and sometimes damping too.
Regular shocks and springs can’t be adjusted for height. You can get lowering springs, but you still have a set height on them, I’ve only ever seen lowering springs at 40mm lowering which is the limit for shocks. Coilovers can be adjusted as much as you want within the limits and can go lower than regular shocks.
