Hi I have the perspex mazda one fitted very effective was on car when I brought it so cannot tell you the difference from the small factory fit one… One thing to bear in mind if you fit a solid one you have to get out of the car to raise or lower the roof on the nc …unless you have long arms…
I got the mesh deflector and find it obscures the view in the mirror, the thick black top edge is dead centre in the mirror view for me, have tried adjusting the seat height but made little difference.
It is easy to fit and swap back to the original which is needed in the warmer months. No drilling or screwing into the plastic hoops etc needed.
Hi,
I also have the perspex wind deflector on my MK3 Sport. It was fitted by the dealer for the first owner when the car was new.
When I initally bought the car, I was not sure if I would like the perspex idea, but I am a total convert - it is brilliant!
It works incredibly well, and makes driving my car even in cold weather, a real pleasure.
Hope this helps!
I tried the MX5 Parts perspex wind blocker on my previous MK3. Yes it blocked the wind but no more so than the MX5 Parts mesh wind blocker. I discarded & sold the perspex wind blocker as I found driving at night it resulted in some strange reflections from vehicles travelling in the opposite direction.
With regard to rear vision when using the mesh wind blocker I simply raised the fixing points on the frame by 25 mm, the top frame now no longer obscures my rear mirror vision. I must admit cleaning the inside of my current prht’s rear window requires some flexible elbow & wrist ability, due to the extra height of the wind blocker.
I too have the Perspex type on my Mk3.5, I replaced the mesh type because of same reason as “captainhaddock” and prefer the Perspex even though you do get reflections from the sun and some lights.
I still have the black mesh one if someone wants it for free.
One or twice a month I do a 315 mile (each way) motorway journey. The buffeting can really get on your t!ts after 5 hours. And I should add I find the car pretty awful with the roof up so it’s seldom up…until I start getting wet. So basically I use another car if it’s wet.
