I’m looking for technical help or recommendations on:
Hi all,
The engine bay on my MK1 is very grubby. It looks like has never been cleaned!
What products are recommended for engine bay cleaning/detailing? Ideally, I would like to use something “safe” that won’t interfere with any electricals in the engine bay.
I picked up this and it works a treat. Getting it moved about into all the nooks and crannies with a soft paint brush removed most all of any engine bay crud as was needed.
Purposely NOT dousing electrical parts and taking reasonable care with a spray bottle to move the suds on after you’ve brush worked them is paramount to not having issues afterwards.
Here are a few pictures of the engine bay after a once over with some generic cleaning spray and some rags. As you can see it is in need of a proper cleanup!
Thanks mate, I’m planning on removing the air con at some point so I guess that will be the best time to give her a proper clean when the radiator and airbox are out the way!
Hi. I used Autoglym Engine cleaner carefully washed away with water and microfibre cloths. Then used Autoglym Vinyl and Rubber. Made a massive difference in my grubby NC engine bay. Hope that’s helpful for anyone looking for product suggestions.
I think I used the hose sparingly on its mist setting. I was paranoid not to force water into any electrical connections. One thing I did notice afterwards was a slight chirp from the auxiliary belt on cold start ups. Might be unrelated but I could have inadvertently got some of the rubber care product on the belt causing a slight slip. It’s quite slippery stuff! Seems fine now but a tip for anyone else. When I clean it again I will spray the product onto a cloth and apply that way and not spray directly onto bits of the engine bay.
Another vote for Autoglym Engine & Machine Degreaser and, if used correctly, it goes a long way. Always best to dismantle as much as you feel comfortable with to get in there.
Marking Autoglym Engine & Machine Degreaser as the solution as it has so many glowing reviews. I’ll be sure to post an update of my clean engine bay once I’ve had some time to sort it out!
