Hi is there a way to unplug the seat belt chime I can’t stand it anymore. I actually wear my belt but put it on pulling off
- My model of MX-5 is: __
- I’m based near: __
That’s kind of the point of it. Just put your belt on before you start the car
I have said I wear my seatbelt in the post. I have to move cars around on my drive so I don’t put my belt on plus I reverse into my work carpark and it still beeps in reverse I am not saying I want to drive without the belt on just want to disable the beeping
Also in the case of carrying something heavy on the passenger seat, one has to remember to do the seat belt up, or be distracted by the chime.
Which generation of MX-5 are we talking about here? You’ve left that bit blank!
It’s a nc 1 thanks
I read a while back that is can be done using FORSCAN
LONG-TERM DEACTIVATION
To deactivate the belt minder long-term, change the configuration of the Instrument Cluster using WDS.
Yep, if it’s an NC then I’d agree. Take a look at Forscan.
