I have recently bought a MK2 and a little more chrome is in order. Can someone please point me in the right direction as to how we get at the dials to fit the detailed Instrument Rings along with needle covers. Please accept my apologies if this has been asked before. I have looked but knowing me in the wrong place.
Pop the top of the stalk cowl off, pop the instrumemt cowl off amd you will see 4 x phillip head screws, unscrew them and the cluster will be loose ,unplug the connections from the back, you will then see that it will just pop all apart, do not use super glue, go to your local autofactors and get a blister pack of clear automotive sealant, don’t go mad with it just a couple of dabs will do the job. and then just refit when it has gone off.
Thanks for the replies and advice re superglue. I have only had my MX5 for a month and I know it has been ‘modified’ cosmetically. I have attached a couple of pics of the dash. I know the car is a MK2 but the chrome rings on the speedo and rev counter suggest (to me with ltd knowledge) a mk 2.5 dash. Having looked at MX5 parts its either a complete set of chrome instrument rings for eg:
They should all fit ,and yes it is a Mk 2.5 cluster,just get the 3 rings needed as you have rings on the speedo and rev clock anyway, but if you want them to all look thesame? then the Mk 2 ones should be the same
I have replied, easier to talk than tap tap, so my number is there, there are are a number of things to check, i wont be free until around 1’ish, so i’ll chat then Ric.
Get hold of the cluster on both side and pull towards you with a jurk to release it from the speedo cable socket
Then unplug the 2 electric plugs from the back( note this is the early type, the later type will have another connection to unplug for the Heated rear window warning on light, on your left on the rear)
The only thing to have changed from these pics are the rear light clusters now, they have been swapped for some morette rear light units, if you want pic’s of the back end, let me now, but at this time of year she will be a little dirty, as she is used everyday.
I plan to fit white dials soon and shall use this excellent guide.
i noticed on a couple of your pictures that you have the same immobiliser fitted as i do located near the ignition barrel. Just a shot in the dark ,do you have any info on this immobiliser ? i have a second immobiliser key that you touch the mounted led unit with but it needs to be coded and i dont have any instructions on how to do so.
Great guide only other question is once you move the cluster any info on replacing the dials removing the needles ect i read that one person saying to make sure you have a full tank of fuel to replace the fuel dial any advice appreciated thanks
