Hi all!
I want to repaint some wiper arms, as the black paint has largely come off. My plan is to abrade the surface with wet-and-dry paper, then repaint. I have rust-o-leum satin black paint, do you think I can get away without primer? If not, the only primer I’ve got is Rust-O-Leum’s plastic primer (used to repaint the ashtray!) - would this primer work on metal?
Thanks for any help provided!
Simon
plasticote satin black top coat with the black under coat is the stuff to use.
M-m
I used that plasticote, its good stuff, rubbed them down well, sprayed whilst hanging on the linen line, no special under coat at all though, did a year or so ago and still look good… No doubt the more layers the better…
Well in the end I went with a plasticote anti-rust metal primer as my dad had some in the workshop. First I took the wipers apart and sanded the parts down with 240-grit wet and dry paper, then cleaned with white spirit. 2 coats of primer went on, then 3 coats of Satin Black top coat (Rustoleum multisurface rattle can)
The end result is drying off now, but certainly at this point the finish looks superb - signifincantly better than stock wipers, the finish is much nicer. Ironic really as I’m only doing this so I can put these up on eBay - I got decent replacements from a breakers yard, just wanted to tart these up to make them saleable, but now I’m wondering if I’d rather keep them and sell the other ones! Tough call…
Erm, what? Did I do something wrong?
Realise this is an old thread but couldn’t find a newer one. This sounds great, I’ve got some kurust and black satin paint, but how on earth do I get the wiper blade arms off? Haynes repair manual offers no help.
Thanks! Managed to get it off with a good bit of WD40
Just wanted to thanks for the plastikote tip - one can of black primer and one can of satin black and the wiper arms on the Eunos look as good as new. Even managed to pickup a small spoiler thingy , so the whole assembly is back as the factory designed it
Cheers ![]()
Just recently did mine. Sanded down with 400 & 800 grit, then cleaned with degreaser. Then just used Hammerite smooth black I think it’s called. I very lightly sanded with a 1200 grit after coats 1 and 2, then just applied another 2 coats. Perfect finish and also not a high gloss finish, more like a semi-gloss
. Added new blades too as the others were slightly rusty and took away of the “new” look arms
