Hello,
I need to replace the front Windscreen I have 2 hair lines Shape on the driver side , my insurance is with AA and they using AUTO WINDSCREENS does anyone know if they any good? I have a soft top do they need to remove the inside plastic frame with the two screws where the second part of the mechanism is for the soft top? I have read some reviews for that glass company and are not very good so I am worried if am honest. Does anyone know please,
Many Thanks
We used them at times at a main dealer . Some times there work was not that good leaks or broken trim. I’m not sure about now but there fitters went on a one week corse then they where on there own.
Wouldn’t have them near mine.
Oh God… any ideas who I should use I had a feeling there are not good so many bad reviews I don’t mind paying private.
Any ideas around Berkshire I live in Windsor or near Slough , do you know if they need to remove that plastic panel from inside to remove the glass ? You know I rang Mazda in Guildford they told me they are not trained to fit a glass.
There is no need to remove the plastic panel. These screens are bonded in . They use a tool like a cheese wire to cut the old one out… No idea for a fitter as i.m on the south coast. Most main dealers use Auto glass…
Used them through my insurance company when it cracked.
Actually went beyond customer service as bought a windscreen which was not specific for my car.
Reordered and fitted and perfect ever since.![]()
Each review will be perhaps different. ![]()
At least I don’t have to worry for them removing the panel. yes Auto glass are good but my insurance AA dealing with Auto windscreens , but thank you for this information…
Autoglass or Autowindscreens ? Auto Glass are more popular but yes as you said each review is different …
Just checked it was Autoglass.![]()
Apologies if I misunderstood your post.
Is fine , thank you for checking . ![]()
I recommend you get a Windscreen Cowl Leak Repair Kit from mx5parts because invariably the windscreen fitter won’t replace them and if you don’t you will more than likely get a leak in your passenger footwell (search “scuttle grommets” in this forum). Also recommend to put sealant round the new grommets when fitting.
https://www.mx5parts.co.uk/windscreen-cowl-leak-repair-mk3-35-p-4597.html
Just to add they will need to remove wipers and the scuttle panel.
I can only say Autoglass did a good job on my daily driver. Just left them to it, done through insurance. I contacted them for fitting, they preferred to come out to my home although we have a local fitting centre in the city. They just dealt with everything insurance wise I think like most do but just checked who insured me before booking the fitting.
II think Autoglass are better but my insurance using Auto-windscreens lets see what happens I have booked the Caron the 13th
wow … I will order them now thank you for showing this photo
