- My model of MX-5 is: __NC3 PRHT
- I’m based near: __HULL
- I’m looking for technical help or recommendations on: __Replacing rear shocks
Looking to replace rear shocks, is it an easy enough job, just replacing them with standard ones nothing fancy.
Cheers
The boot trim needs removing to access two of the nuts holding the shock to the car.
I would say the most difficult part is swapping the old shock parts on to the new shocks if you don’t have the correct tools.
( OEM shocks arrive as just the shock - not the full assembly )
Hi Dean
Thanks for getting back to me, I did a bit of research and most of it seemed pretty straight forward, but didn’t know about swapping bits from the old to the new, I’d need some spring compressors anyway but if I have to buy any extra kit then I think I might as well take it to my local garage they’d probably be able to swap them both over in an hour or so.
Thanks again
