My stereo is playing up, turning itself off. I’d like to replace it with something similar, any recommendations for another Sony 4 speaker stereo? I’m having trouble identifying something with the same outputs on the back
thanks
thanks
If you have photo we may have “original” Sony but need photo to identify
Hi - hopefully attached/inserted
This stereo is at least 15 years old .It is unlikely you are going to find a unit with similar connectors on the back. Most current models have standard iso double block connectors. Size is the same,as this is a regular single Din fitting.Re-wiring another unit is fairly easy.
