Replacing the Mk1 Battery Vent Pipe Grommet/Gasket?
  1. My model of MX-5 is: Mk1
  2. I’m based near: Lincs.
Does anyone know what the rectangular, round cornered, rubber gasket/grommet is called for the battery vent pipe, where it attaches to the floor of the boot area.
Mine is quite brittle and has broken so I was thinking about trying to find a replacement, but the usual parts sites don’t return any results for it so I was wondering if they were a generic part that could be found on eBay etc? or do people make their own?
Thanks.
Connector, tube-battery, B61P-18-526
Autolink has aused one in stock:
Though the one illustrated I think is missing an o-ring or something.
A French supplier, same part for NA/NB?
IL Motorsport also has it:
Thanks for the reply.
My actual connector is fine, it’s just what you refer to as the O-ring that has perished and that I was hoping to find a replacement for.
If this should come in handy for someone in the future…
The Gasket/Grommet/O-Ring dimensions:
Overall Length: 25mm
Overall Width: 20mm
Overall Height (Thickness): 2mm
Width of the flat (Outside edge to inner edge): 4mm
An example of a custom made gasket can be seen here.
