When I open and close my roof, the cover has started making a clicking/clacking sound and shakes a little as it closes down. I’ve greased the cogs and all looks and works ok except for the noise which clearly can’t be right, any advice greatly received.
I think the first thing to check is the two allen screws that you have to undo if you have to raise the roof if it fails when down and you have to raise it manually. There is a long allen key in emergency tool kit for the roof. There are instructions on how to do this on this forum, but for the life of me I can’t find them at the moment. These bolts have been known to come loose and cause juddering.
Okay I’ve had a bit of a search and this shows the bolts I was talking about.
https://forum.miata.net/vb/showthread.php?t=392593
Hope that helps.
The instructions are in the owners manual.
Cheers will have a look this evening.
Thanks for the info, problem sorted
Glad you got it sorted. Pleased to help ??
