retro fitting powerd stearing
hi all wantimg to fit powerd stearing to my car bought a set off part to do it but mine has no a/c so is the belt shorter or would I nead an aux pulley instead off a/c pump also the oil cooler pipe does it mount to right side/passenger side off engine cant find no pics or diagrams to show pulley set up or routeing off pipes Haynes manual crap as normal thanks jeff from portsmouth
Power steering will fit mk1 regardless of whether it has AC or not.The belt may be shorter but not need for auxillery pulley.We have full kits here or parst loose if you need them and the cooling pipe is fitted to passenger side and goes out through the anti roll bar bracket .PM me if interested and I may be able to advise you
