Recommended procedure for recommissioning a 176k miles MX5 that’s been sitting in a barn for 12 years? I think the following may cover most of it:
- Plugs out fill bores with diesel or light oil and turn over with a spanner (if free see 2.)
- Drain fuel tank
- Block off fuel line
- Top up water / oil
- Fit battery and turn over briefly with plugs out (cloth over cyl head re diesel)
- Add plugs
- Spray Easy Start into manifold and attempt start (release clutch if stuck)
- Fault find if no start
- If starts briefly take out plugs and take compression test
- Empty fuel tank
- Check all levels, add small amount of fuel (external tank) and attempt start - run for 30 seconds.
- Check oil pressure OK
- Fit new Ethanol rated fuel lines
- Re-check all levels an run until warm - check coolant flow, oil pressure (Edit: Check coolant hoses / clips etc)
- Re- check all levels and run until hot / fan cuts in.
- Allow to cool and re-check compression
- Pump up tyres
- Start, check all gears and attempt to move
- If moves forward and back ok check steering, brakes (test run around paddock)
- Jack up and check for loose steering and suspension bushes, bearings, exhaust blowing, rust, brake lines, etc.
- Remove head, check valves and bore wear (history unknown - could have been rebored?)
- If required remove engine for rebuild / rebore / head skim if warped
- Replace clutch
- Check and replace any time limited items (seals, new water pump / new cam belt / alternator belt and anything that cannot be reached easily when engine in place. (Edit: check oil pump strainer and back lash on lifters)
- Add any aftermarket items as recommended since vehicle first built
- Clean up engine bay and replace any crushed or worn wiring, pipework etc
- Remove fuel tank clean if needed or replace if required
- Welding as required on underbody if needed
- Replace fuel tank
- Replace all bushes and bearings.
- Check and rebuild Master Cylinder or renew
- New discs and pads and service calipers (and paint!). Replace brake lines.
- New brake fluid (Dot 3?)
- Hand brake servicing
- Update suspension
- Refurb wheels
- New tyres
- New windscreen
- Check electric window winder motors and re grease etc
- Check all other items (lights, heating, etc)
- Update paint etc
- Take to appropriate MOT station (NOT ‘Kwik Fit’!)
- Fix all the MOT fail points (!) and address Advisories as required.
If anyone has done this - have I missed anything?
I know it would be cheaper to go and buy a new one but I run a '96 Alfa Spider so used to throwing money away. Besides I’m retired so need a project in addition to the 4 bikes and 7 cars.
