RF Roof control Smart Top
  1. My model of MX-5 is: RF ND2
  2. I’m based near: Watford
  3. I’m looking for technical help or recommendations on: Smart Top Roof Controller
I am thinking of buying and using a professional installer to fit a Smart Top which allows, one touch opening, open and close up to 30mph and remote control via the key fob
Does anyone have any experience of these
The car is nearly 3 years old and still under manufacturers warranty, so am waiting till after the 3 year service to have it fitted, as I guess it will negate the warranty
I’m amazed this hasn’t been included in later models such as yours as it’s basically a software addition to the hardware already able to do the physical bit.
It’s about £350 for the aftermarket stuff.
Mine takes 12 secs and that’s nine seconds too long😀
I used the MX5 things controller and fitted it myself following a YouTube video. Quite straightforward if you are handy with a screwdriver but shouldn’t cost too much if you need to pay someone to do it for you.
You can set it back to factory defaults using your key fob so the garage doesn’t know it’s fitted which is what I did on my year 3 service.
I would go for the 3 part fitment from MX5Things UK based stockist its a lot better as I have had both types and the MX5Things has a few more things you can install to your key controller … fitting is easy its all plug in and play plenty of UTube vids to help you out as well
