Ride height is measured from the centre of the wheel hub to the underside of the centre of the wheel arch.
The specs are
Rear 346-395 mm
Front 328-377
The difference front to rear should be 10 and 30mm with the rear being higher
Aim at 340-325 as a good road setup.
The difference side to side on the same axle should be no more than 10mm
