- My model of MX-5 is: __1996 Mk1 1.8
- I’m based near: __
- I’m looking for technical help or recommendations on: __ Diagnosing possible cause of engine running rich
My Roadster has struggled through emissions for a few years, and munched catalytic converters.
The engine is on about 120k kms, but the ancilliaries (original engine) are more like 170k miles on them (original inlet manifold and bits were fitted to the replacement engine fitted many many years ago).
The garage that looks after the car has tried alternative Mass Air Sensor, which “worked” for a while. Tried new water thermisters. I’ve got a new O2 sensor on… New(ish) spark plugs. Last time, for the MOT it was sent through with a loaner cat, and then the old one refitted
At the next MOT the garage is suggesting looking at doing a top end rebuild.
While idly researching, I thought about perhaps a failing fuel pressure regulator.
While the engine pulls strongly (it doesn’t feel worn out), fuel consumption seems ok (though it doesn’t get driven much these days, enough for me to closely monitor consumption), there are a number of symptoms:
- Sooty tailpipes. Though all the MX5s I;ve ever had has had sooty pipe. But no visible smoke.
- Idle when hot; when pulling up, the tick over will dip down, and the engine will bog down. I’ve become a bit of a blipper of the throttle.
- Starting; it cranks fairly slowly, but always starts. New battery. Sound terminals. Replaced the earth/ground from battery to PPF.
I;ve yet to check the vacumn line on the FPR; my understanding is if I smell fuel, the FPR is shot. I was hoping to find a replacement part fairly cheap, and just swap it in. But rather shocked that I can’t find a UK supplier, only in Germany, and the Mazda part is fairly expensive. No pattern parts seem to be available in the UK it seems (unless someone can point me in the direction).
The other possibiklity is a hairline crack in the MX5parts 4-2-1 header that I fitted back in 2005. A few years afterwards, one of the welds on a header started to fall apart, but I had the manifold welded by an engineering company. The repair still looks perfect.
Any thoughts on my thinking? If engine rebuild is needed, then that might be me done with this car, and call it a day with MX5s. Obviously I am trying to avoid a 4-figure bill on a car with 270k kms on it.
