What I’d do
1 Go to your local paint motor factor and get your car matched, just because you have the code or name there is more to it than that. There will usually be variations caused by either paint or technique variations at the factory. See below regarding Mazda 11R
Colour Chips
Actual spray outs
When you have sorted out your can of colour (do a quick colour check by spraying a test piece) and a can of clear lacquer
2 Flat off the area you have painted with 1000 wet n dry (used wet) so its all nice and smooth and dull.
3 Using a grey scotchbrite pad and a bucket of water you need to take the gloss off the surrounding paint work for about 6" in all directions, rinse with water when done.
4 Mask off when dry but rather than do as before try this
Use paper a tad more substantial than newspaper like white A4 printer paper
Put a strip of tape along one edge and then place the paper on your car in a way that the tape is on the edge of the shiney paint work and the paper covers the area you want to repair. Now bend/fold the paper back over so it rolls over the edge that is stuck down so you have a
This will stop any edge where the new paint ends.
5 The aerosol has a fan of around 3", so be sure to have only 1.5" going on the arch (or what is needed to coat the repair area) and the other 1.5" spraying in to the wheel arch void (fill with an old curtain or similar). With an aerosol keep it tight, it is easy to let a repair grow and grow with each coat until it becomes unmanagable. The technique is important, apply too light and the paint shade will be too light as the aluminium flakes will sit on top, too heavy and the colour will be very dark as the aluminium flakes will sink in the layer of wet paint (it sound much worse than it is in reality). The feathered edge of a aerosol fan and its low covering should be enough to hide where the new paint ends.
Apply 3 coats with 10 mins between.
6 After 30 mins apply 3-4 coats of clear again with 10 mins between coats, when lacquering spray 2" beyond where you sprayed with the basecoat
7 After an hour or two de mask and then with plenty of elbow grease you need to polish the repair (gentley) and the surrounding area that was dulled off to bring the whole area back to a nice uniform gloss. A polishing compound rather than T Cut is advisable.
All the above sounds long winded and hard workand maybe £30 more than planned but it will give you the best chance of a repair that blends in well. To mask out a fixed shape, paint it and de mask will always stand out with metallic paints.
A decent motor factor will spend 10 mins going through the reapir process.
HTH
