OK, I might be missing something obvious here … but where’s the search function hiding? I’ve looked everywhere on the forum’s top-level index page, and can’t see it ; I’ve also navigated down into some of the sub-forums, but still no search button. Where is it?!
Top RH corner of the home page
http://staging.mx5oc.co.uk/forum/search/
except that takes you to a Staging version of the forum…help…[:$]
However try this one
Right, so there is one - but where’s the link to it from the main forum index?
I’ve just had a look at the code behind the page, and it’s pointing to the wrong place, I can’t change it[8o|]
But that’s the point - I can’t SEE a link from the main forum index to the search function, whether it’s one pointing to the right place or not! Where is it?!
There is no link for it at the moment I believe, it is on Martin’s list though.
If you just use the link that geoff posted for now (maybe add it to your favorites list?), since it does the job until things get sorted out properly.
