Bought a new ND recently. Awesome car, and real thrill to drive.
But my wife isn’t the tallest and requires some elevation in the car to feel confident. We have toyed with some foam cushions on amazon which worked but the shape wasn’t ideal for the seats. With the ND not having a height lever I wondered if anyone has come up with a solution to this or has a memory foam type seat cushion? Even for older cars?
My cushion is 90mm tall by 360 front to back and 370 wide. Just fits into a Mk1 seat if that helps. Product is labeled Putnam’s PL7 5ET
Cheers, Twofives
The occupancy sensor in the ND is clever, it can tell whether a child booster seat is being used or not. It doesn just detect weight it looks at whether a bum is actually on the seat or not.
I was enquiring about using an adult memory foam wedge cushion as sold by Halfords in my NC2 .As the seat height is not adjustable a short passenger sits very low in the car and consequently has a limited view through the windows. The car frequently goes to Scotland and my partner does miss some of the scenery.
I had this problem even in my mark2 and resolved it the same way as i have done in my mark4 which is much worse from my point of view,i removed the rear seat rail bolts and put a few washers under the rail to raise rear seat height then used longer bolts,problem completely resolved the view is much better,i feel much more confident driving the car,i see no real problem with this cure and know of several people that have done this.
Removing the bolts is difficult as they are glued in and you need the special star shaped socket on mark 4,i then brought good engineering quality bolts,i raised my mark 2 by five washers,i think i have raised my mark 4 by eight washers,you do need to buy good quality large plate washers which spread the load and stability well.
Hi all,
sorry to resurrect this old thread but…
Can someone please advise the best place to buy the required quality bolts and washers? And the exact bolts and washers to buy?
I found this thread on the 124 forum https://www.124spider.org/threads/raise-the-seats.37070/page-2 and also found this website https://www.accu.co.uk/
However, searching the accu website I cant seem to find the exact matching bolts - particulary the stated thread pitch size of 1.25mm?
Just to confirm I would like to raise the seat by approx 30mm
Thank you.
Thanks, Screwfix was the 1st place I checked.
However, I couldn’t see any 1.25mm thread pitch size.
I have since found a few other sites which seem to offer what I need - but will wait if someone does respond with recommendations.
Cheers
