I have a mk2.5 and recently removed my airbag steering wheel so I have changed my seatbelt for one from a mk1 so it doesn’t have a pretensioner. This has obviously caused the airbag warning light so I want to fit a resistor to trick the system. My problem is I can’t find much information about which resistor to use. I have found a write up saying to use 4 x 10ohm resistors but this hasn’t worked.
but air bag light can only be failed for staying on and showing a fault , you can only advice it for not coming on at all
you can also fail a car for air bags missing when fitted as standard but theres no info for specific vehicle fitments so this can vary from station to station .
I plan on having to put the steering wheel back on if and when it fails the mot but, changing the seatbelt back is a lot more work as it is bolted in quite deeply to the roll bar. I’ve had the mk1 seatbelt restored and re webbed so it’s fine to use. I just don’t want the light on
Thanks for the info. I was thinking about just removing the light but I was worried that the system would still be in am error state due to the missing seatbelt. I assuming that if the system is registering an error then if I did have a smash then the passenger airbag and seatbelt pretensioner wouldn’t deploy.
I don’t mind messing with my safety as my theory is I ride a motorbike everyday so it has to be safer than that, but I don’t want to mess with my passengers safety.
