Doug
27 July 2013 07:04
2
Getting this error when trying to reply to ‘For sale’ items.
Server Error in '/' Application.
Cannot insert the value NULL into column 'Indent', table 'yafoc_live.dbo.yaf_Message'; column does not allow nulls. INSERT fails. The statement has been terminated.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: Cannot insert the value NULL into column 'Indent', table 'yafoc_live.dbo.yaf_Message'; column does not allow nulls. INSERT fails. The statement has been terminated.Source Error:
`An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.`
Stack Trace:
[SqlException (0x80131904): Cannot insert the value NULL into column 'Indent', table 'yafoc_live.dbo.yaf_Message'; column does not allow nulls. INSERT fails.
The statement has been terminated.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +2084358
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5096328
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2294
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +215
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +987
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +178
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +137
YAF.Classes.Data.MsSqlDbAccess.ExecuteNonQuery(IDbCommand cmd, Boolean transaction) in D:websitesyafOCBetaYAF.ClassesYAF.Classes.DatamssqlMsSqlDbAccess.cs:445
YAF.Types.Interfaces.IDbAccessExtensions.ExecuteNonQuery(IDbAccess dbAccess, IDbCommand cmd) in D:websitesyafOCBetaYAF.TypesInterfacesExtensionsIDbAccessExtensions.cs:48
YAF.Classes.Data.LegacyDb.message_save(Object topicID, Object userID, Object message, Object userName, Object ip, Object posted, Object replyTo, Object flags, Int64& messageID) in D:websitesyafOCBetaYAF.ClassesYAF.Classes.DatamssqlLegacyDb.cs:5563
YAF.Pages.postmessage.PostReplyHandleReplyToTopic(Boolean isSpamApproved) +929
YAF.Pages.postmessage.PostReply_Click(Object sender, EventArgs e) +572
YAF.Controls.ThemeButton.OnClick(EventArgs e) in D:websitesyafOCBetaYAF.ControlsThemeButton.cs:433
YAF.Controls.ThemeButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) in D:websitesyafOCBetaYAF.ControlsThemeButton.cs:388
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +176
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1008
I had that, had to shut down and reboot
01mx5
27 July 2013 07:34
4
This should now be sorted - it was caused by part of the data import not setting something correctly.
Edit:
Doug
27 July 2013 11:36
5
It would appear to be so. Thanks
