Do you think this is a good price for a service. , I have a 2011 1.8 had it about 6 months
Its not got a full service history but thinking this would cover all bases
5/30 Engine Oil, Oil Filter, Air Filter, Ngk Iridium Spark Plugs, All Levels Inspected And Topped Up, Brake And Tyre Condition Check, Tyre Pressures, Gear Box Oil Change And Differential Oil Change, Brake Fluid Replace & Bleed, Clutch Fluid Replace & Bleed Coolant System (Antifreeze) Replace And Bleed. £380 + Vat
If it’s not been done, consider getting the thermostat and possibly the water pump done while the coolant is drained. A new stat will probably drastically shorten warm-up time compared to an old tired one.
I had the Mazda basic service (inc. oil and filter) + MOT done for £319 at a Mazda main dealer just this week. I don’t think this would have included spark plugs, clutch fluid or coolant. Just so you can compare.
For comparison, a 3 year service plan on a new SkyActiv-X Mazda3 (the oil costs more) is £899, so about £300 per service. No MoT, obviously, but includes the more expensive year 2 service and the Supra-X oil. Generally it works out a little cheaper on a plan and, of course, is inflation-proof.
