Hi,
I’ve been trying to remove my drivers side manual door mirror on my mk1 (as it’s getting a bit stiff and the passenger side snapped off once it reached this level of stiffness) to use a fixing kit on it, however one of the two screws doesn’t want to turn. It will turn 45 degrees to tighten itself, but not to loosen it. So far I’ve tried:
- Copious amounts of WD-40 branded fast release fluid.
- Standard screw drivers of various handle sizes (with PH/PZ3 heads which seemed to fit best).
- Drill with screw driver bit (this was the only way I managed to get the screw that's out out).
- Ratchet screw driver with above heads.
- 4 pound lump hammer (used lightly).
- Lighter, small hammer (again used lightly).
It still however refuses to budge.
Does the screw go into anything on the other side under the interior door panel or is the thread it goes into part of the door skin itself? Ideally I don’t really want to take the door panel off to see if I can do anything from the other side or risk damaging things by attempting to drill it out but I’m running out of ideas as to how to get it to start moving so I wondered if anyone else had any suggestions?
Thanks.
