Hi folks,
My NC 2006 2.0L has thrown a spanner in the works.
I had the engine running with the heater fan on to try and dry out the passenger side carpet as the windscreen scuttle panel grommet needs replaced.
Car was running for around 15mins then the car shook momentarily and started making a noise like a rough bearing or similar. I opened the bonnet and everything looked normal and the noise continued. soon after smoke started to appear from the rear right hand side of the engine along with the dreaded burning smell.
I quickly turned off the engine and the smoke drifted away with no obvious signs of any damage.
I’m going to go back to it later when it’s all cooled down and have another look.
Has anyone experienced this with theirs?
I took the key out and put it back in the ignition. Turning the ignition on all lights are normal, turning to the Start position and nothing happens at all, no flashing light code. just dead.
Does anyone have any ideas?
Thanks in advance,
Dean.
- My model of MX-5 is: 2006 2.0l
- I’m based near: __Paisley
