I’m looking for technical help or recommendations on: Brakes
I changed my disks and pads the other day but the Haynes Manual said to put the low brake pad indicators on the outside pad but when I took the pads out they were on the inside pads.
I thing Haynes are correct.
The wear indicators are always on the inner pad from the factory. The inner pad always wears quicker than the outer pad. I don’t fit them to my pads as I think that they tend to make the pads stick in the carriers a bit. I just monitor my brake pad wear visually.
Thanks’ for that just what I was thinking of doing, one of my wear indicators had scored the inside of my disk although there was loads of pad left, I have replaced all disks and pads even though they were ok really.
I have the 1st Edition of the Haynes NC manual, and it is riddled with mistakes and omissions I’ve spotted, and very poor illustrations, so much so I don’t trust it at all in case of other errors I’ve missed, so now it’s just using up half an inch of shelf space. What a pity.
Can someone check the NC Haynes for which GL number oil it suggests for the 5 and 6 speeds? I have a feeling they have it right and that some Mazda owners handbooks actually have it wrong…
Yes that’s correct, at least from 2005 onwards on the NCs anyhow.
The actual Mazda NC owners handbook states GL 4 or 5 for the 6 speed which is wrong, it has to have 4 in it.
Are you sure there is a specific Haynes NC one?
I am only trying to help, I went to the trouble of unearthing my Haynes manual and have tried to be as clear as I can as to what is in there.
Please and thank you are a no cost option.
