Soft top replacement recommendations
Hi all,
I currently own a mk1 1.8 and the roof is getting a bit worse for wear, with rips and tears making the car leak prone.
I was looking for any recommendations for a place that would supply and fit a replacement. I’m primarily looking for a brand new vinyl roof with a plastic rear window.
I’m based near Milton Keynes but am willing to travel to get the job done properly and to a high standard.
Thanks in advance.
If you want a quality job done then it’s worth speaking to Paul at The Soft Top Shop, but he’s based in Stockport. He does travel but Milton Keynes might be too far for him. Perhaps you could meet him halfway - he only needs 2-3 hours to fit the hood if I remember right.
Jack Smith in Swansea if you fancy a day on the beach …
Will check out both. Thank you
Its not as hard as you think to do the job yourself correct and very satisfying…
http://www.mazdamenders.net/forum/viewtopic.php?f=114&t=7087
M-m
