Iâve been waiting on the Soul-red touch-up paint kit for almost a month now after a tiny ding appeared high on the rear wing of the Mazda3 near the filler cap. Eventually I put in an order to MX5 Parts for this and a couple of other things and they sent me the kit as soon as the stock arrived, while keeping me updated on the stock status in the meantime. Excellent service.
Interestingly for the Soul Red 41V, both the âbase coatâ and the âclear coatâ have colour! The âclear coatâ is tinted and not full colour. This is a proper Mazda part, and it includes good instructions on how to use it with relevant timings, ambient temperature range, and a neat little abrasive/polishing pad on the top of the âbase coatâ pot for flattening it before applying the âclear coatâ. It also suggests a shelf life of only 24months.
This is new to me as the equivalent Icy Blue kit for the Niseko uses a totally clear âclear coatâ, and no polishing pad, and no instructions etc, and no shelf life mentioned.
I got some of this after I managed to ding the front splitter on my Icon on the stupid kerbstones in my work car park, which are a foot high for some reason.Â
I did notice the colour tint to the clear coat after I put the first coat on and thought âHang on a minute, thatâs not the right colourâŚâ. I trusted though and as soon as the clearcoat dried the paintwork looked perfect again. Itâs good stuff for the price.
I also find the colour match to be very good once the top coat is applied. Although I found the Soul Red touch up was cheaper from my local Mazda Dealership than MX5 Parts.
Â
I ordered it on a Monday and it was ready for collection the following day after lunch time.
When I first found the ding nobody seemed to have any genuine stock, on several tries a couple of weeks apart, and it was easier to put it on backorder with MX5 Parts for not much difference in price.
The chip hole is now almost invisible, even though I know where it is. The most difficult part was being very careful when pushing out the tiny dent in the metal only just enough to be smooth again.
Below are instructions for using the official Mazda 46v soul red touch up paint. Does anyone have experience of using the supplied absorbent pad to remove excess paint (see stage 6/7) ? Iâve always managed to put on too much paint so this looks a good ideaâŚassuming it works.
Would appreciate any tips before I try to cover 3-4 tiny chips I have on my bonnet at the weekend.
Iâve just used the 34k paint (white) with the same instruction leaflet. TBH I didnât use the soft dabbing pad on the end of the stick, thatâs not to say it doesnât work.
Instead of using the supplied brush I used a fine artist brush after dabbing some out of the pen touch-up into an old plastic cap, jam jar lid or similar will do. Its drys quickly so you have to work with speed. About two coats I used then then the clear coat did the job.
As I read it the paint is water soluble, I didnât know so used around 3-4 artist brushes and threw them in the bin after use, they were cheap enough.
I got bitten by a company selling 34k (pearlescent white) touch-up paint. It was half the price of the Mazda touch-up paint pack. Absolutely useless match it looked silver when dry.
Bonus, my daily driver is Reflex silver (SEAT colour) and needed some touch up paint for that, it matches perfectly.
So buy the official Mazda paint, either dealer or mx5parts supplied.
Thanks for the replies ⌠fortunately my chips are absolutely minuscule, so overpainting will be the biggest risk . Iâll use an artistâs brush and pluck up the courage to dab the paint with the supplied âblotterâ as per instructions,if I over do it ⌠see picture
Tooth pick/ cocktail stick or a self propelling pencil or failing any of these tools a bit it masking tape folded over on its self several times to produce a point rather than a brush if the chips are that small
Far easier not to put too much paint in than remove it latter
The base coat is water based, any over paint can be rubbed off with the soft gauze pad. If you mess the base coat up (and I did a few times) the whole repair can be washed off and started again.
You wonât get that option though once the top coat is applied.
The result I got was outstanding and it was a nasty chip I had
Knowing that the paint can be washed off as you explain, it now makes perfect sense that the instructions say you should use the supplied âblotterâ which has been dampened to remove any excess⌠thanks
I have the Mazda soul red touch-up paint, followed their recommended method and it works, cleared up car park rash dings on the wheel arch, door skin and wing mirror successfully. From 3 feet away I canât tell where the marks were.
