Hello anybody tell me what size socket it is for a mk1 1600cc eunos ,also is it best to get 3/8th and with rubber in or magnetic what do you use, also is the gap pre set.
thank you
thank you
10mm
If you have a socket set without a plug socket get a socket that suits your existing ratchet either 1/2"or 3/8"
If you are not intending to do lots of car mechanicing use one of these
Most people use one with a rubber insert you can now get a magnetic socket. never used the magnetic one.
Never assume anything, get a set of feeler guages as well to check before you install the plug.
